There was no give in the hand lever so something was frozen. Cracked the bleeder on each side, one at a time and got fluid on both wheel cylinders, so that ruled out the master cylinder. Squeezed the dickens out of the hand lever and one side of the left wheel cylinder moved. Time to replace the wheel cylinders. I figured they were the issue. I've been soaking the choke circuit plunger for 3 days now. I had to go to town today so I stopped by the motor sports dealer and talked with a mechanic there. He said he's drilled a hole in the brass plunger and used an ez out in the past, that he'd seen it before on these Mikunies if they've sat a long time. I hate ez outs. So me being me I grabbed the cable right at the bendy bit and pulled so hard the cable came out of the plunger. I did get it loose but now I've deformed the bore by tapping the wrong thing with a punch. Theres a land in the bore i thought was the plunger. I forgot the plunger waa brass. I'm hoping I can get in there with a scraper and clean that edge up.I'm good at making work for myself.
