No spark on 2001 scrambler 400 4×4
143 Views 3 Replies 2 Participants Last post by  Mech
I just bought a polaris scrambler 400 4x4 for cheap because it didn't have compression or spark, I already fixed the compression problem which it was only the piston rings, but I can't figure out the spark issue, I already replaced the stator, magneto, cdi box, coil and spark plug, but it's still won't give any spark, I tested everything with a multimeter and everything works, but when I test the alternative voltage coming from the stator it gives me a really weak reading, if anyone could know what the problem is and could help me, I would greatly appreciate it, Thanks.
Have you checked the operation of the switches, or checkd the wiring from end to end of each wire looking for breaks, using your ohm meter, or inspecting the wiring loom looking for chafing where the wires could be shorting to the frame ?
Yup, that was the problem, there was power going to the frame, thanks I really appreciate it.
Good one.. Have fun.. but don't get caught.
  • Like
Reactions: 1
