I have an issue with my 2010 Arctic Cat prowler 1000. I am not getting spark to the plugs. I have tried the following, after talking to different mechanics and none have worked.
1/ Replaced both coils.
2/ Replaced the stator.
3/ Replaced the computer module.
4/ Replace the wiring harness.
I am out of ideas as I have replaced most of the electrical system, and still am not getting spark to the plugs.
Thanks for any ideas on what else could be causing this issue.
Have you checked the plug wires? Could have corrosion/rust inside the plug wire not making a good ground with the plug, have you tried pulling the plug with the wire still attached, ground it to something like the case or a bolt and see if it’s no spark at all or just a weak spark
Discussion Starter #5
I did read somewhere the instrument panel can cause this, but do not see how? Wanted to confirm before I put another $500 into a new panel.
