help i have 2001 yamaha 400 4x4 4matic and went hunting and came out of woods and noticed oil on my trailer found oil on my drivers side tire rim checked my engine oil its fine where could the oil be coming from
I've never heard of a fuse being between a solenoid and starter due to the high amperage that flows there. Too much for a fuse. I would say your solenoid is probably corroded or dirty and not enough current is passing through it to start the motor. Your battery could also be low or have bad connection on the terminals. Check all your connections first before you buy a new solenoid. There should also be a main fuse between the solenoid and the battery. Here's a diagram that may help.
