To check the ignition you check the cdi's black with white stripe wire makes a good earth, and another wire coming up from the stator, in the book I have the stator to cdi wire is black with a red stripe, that wire should get a AC voltage to the cdi when the motor's turned.
If it hasn't got a AC voltage then either the kill or ignition switches are turned off or faulty and shorting it, or the stator is defective.
Before doing that though you should check your spark plug, and that the HT wire and cap are good.
