I have a carb on a Suzuki atv. I only know what YouTube has taught me about carbs , so be patient 😀
The pilot jet head broke off, I removed the jet as best I could, including usIng a small drill bit to help get it out
I have two questions, firstly could I have damaged anything at the bottom of the jet housing, I definitely didn’t touch the sides where the thread is?
Secondly when I blow air or carb cleaner through the pilot jet , it comes out of a release hole as per the photo. Is this correct, I don’t understand why that would be there as how does the gas get through to the chamber if there is a much bigger exit hole beforehand?
Any help appreciated
thanks
3530
https://www.atv-forum.com/threads/carburettor-question.79328/reply?quote=99047
As long as you got all of the jet out and didn't damage the threads, go ahead and put a new jet in. I believe that small hole is for air to mix with the fuel in the jet to help atomizer it.
