Hey everyone. New to the forum. Have used it just a bit here and there for some advice, but this is my first time posting. TLDR at the bottom. First a bit of backstop.
Got a cheap non running buggy with a yamaha 350. Got the engine out torn down and cleaned. Heads, piston, and jug were absolutely trashed. Went ahead and split the case to look for any further damage, but everything looks clean. So with help from a shitty online manual and multiple YouTube videos everything is put back together the way it goes. Shifts through every gear, forward and reverse work. Everything was fine. Test fit the other crankcase half, bolted 4 or 5 bolts down, got the shifter arm on, everything was fine. Took it back off, put some yamabond 4 on there, torqued all 15 bolts down to 10 ft lbs ( I know torque spec is 7.2, we'll get to that in just a moment). The main shaft is locked. It maybe moves an inch and a half both directions but won't go further.
This first time I thought what the hell, it's whatever I took it all back apart thinking maybe I had screwed something up. This was my first time working on one of these, so I am liable to **** up. Got it apart, and everything was working again. Cleaned it, put yamabond back on, and this time I set the torque wrench to exactly 7.2 lbs. Tightened everything up, and what do you know, still locked. Backed the bolts off to where they are barely touching, and it's tight but spins, back them all the way off, and it spins fine.
Any one else been in this situation? I want this thing back together and running again, but at this point I'm so tired of cleaning this yamabond off the case it's not even funny. I pretty much know its a tolerance issue, but i am unsure of where to go from here. Any assistance would be vastly appreciated. More than happy to upload pictures if needed.
Tldr: When I tighten the bolts on a yamaha 350 even below torque spec, things refuse to move freely.
