Hi Everyone
I just bought a used Polaris 2002 400 sportsman and was wondering if there is things I should pay close attention to in servicing or anything else.
The ATV has 856 miles on it and is in very good condition no marks or bangs on it anywhere and it runs good except battery is weak, and should be replaced.
Would it be wise when I change oils to go with synthetic oils ?
It has only been change once with reg oils, should I change coolant fluid.
i have the 500 ho same year . ifind i need to keep an eye on the front hub lube.it semms to get dirty and smells burnt after about 150km. so i change it very regularily. no fluid concerns from me other than the hubs.
you may want to do a good check over fluids, plug, charge battery, tire pressure, and any grease zerks
