Do you require any special manufacturers tools to change the
rear inner and outer U-joints ?
What is the tried and true procedure ?
Any suggestions for equipment to make the job easier ?
Does Fram make a compatible oil filter for the "E5363E"
filter currently on the machine?
Will 10w/30 oil be good for engine use?
What viscosity is used for the rear diff and front diff ?
This machine appears to have a slow brake fluid leak
at the right front brake cylinder area. However when
pressure is applied from the brake lever there is no leak.
Any suggestions?
Thanks, Jim
Any suggestions?
Thanks, Jim
