Hey guys. I’m over here racking my brain trying to figure this out. A few days ago my Atv started sputtering and would only run with the choke out. So I cleaned out the carb and decided to order a rebuild kit. Well the Atv idles perfect, but if I give it much throttle at all it boggs down, spits, sputters, and will backfire and die. I even put all the original carb jets and hardware back in and still the same problem. I’ve tried adjusting the idle screw and pilot/mixture screw and neither helps. Hope someone can help me as I need my Atv. Thanks in advance.
You might want to find the gas filter and clean or change it. Also, drain all the old gas out of tank and lines. I do not care if you put new gas in, or stabiliser, or whatever, drain it out. clean or change the filter and gas lines.
When you say it " spits back" do you mean backfiring into the airbox ? If so, that indicates a lean condition. Start looking for an air leak.
Mad
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
ATV Forum
75.6K posts
11.8K members
Since 2006
A forum community dedicated to All ATV owners and enthusiasts ranging across all makes including Suzuki, Yamaha, Polaris, Arctic Cat, Kawasaki, and Honda. Come join the discussion about classifieds, troubleshooting, suspension, riding, off roading, maintenance, performance, modifications, and more!
