1 - 7 of 7 Posts
Read the sticky and other posts and there seems to be no grey wire at all under the seat to reset belt light. Is it buried in the factory wrapped wire runs? The wires from the CVT are not grey either. This wheeler is useless with belt light on. The CVT switch is in on position. Any help would be greatly appreciated. Thanks!
Clarify:The sticky says the wires are under the seat on right hand side, thus need to remove seat to get to. Other posts say under the gas tank. Don't see any grey wires anywhere.
Don't have these plugs under the seat. No plugs at all actually just two single in line fuses.:dunno:
It's an 05. I looked all around under the seat by the battery compartment. Pulled out the CDI, two wires w/inline fuses and two clusters w/ black rubber boots on them. No such connectors as pictured.I'll try and get a pic this weekend, its located at our farm an hour away.
Discussion Starter · #6 ·
Also the layout is totally different than your pic. The CDI is mounted vertically in front of the battery and the tools are stored in the rear storage under the taillight.
Discussion Starter · #7 ·
OK..looked above the CVT cover and there are the black and gray connectors there like stated in the 650 instructions but they are both connected(gray not just a reset plug) and the black feeds to the starter. Switch them around as per instructions? Don't want to fry something.
1 - 7 of 7 Posts
