Have an '11 Griz 700 that hasn't been started in a year due to a dead batt. I'm about to put a new one in and crank her up.
Should I do anything to the engine to prep it for running after sitting for so long? I'm thinking in terms of pre-oiling parts that the oil would have long fallen away from. Would it be a stupid idea to use a turkey baster and put some engine oil into the spark plug hole? Crank it a couple times, replace the plug and then try to start it?
I'm afraid of rubbing metal parts together during the start before the oil pump gets everything lubed.
Discussion Starter #2
anyone?
Also, does the cylinder sit vertical to the ground, or at an angle? I'd like to put in just enough lube to cover the top of the piston head.
