I have a 2005 raptor 660 and all of a sudden it is really hard to shift into second. It keeps getting stuck in neutral. If I use my hand and give it a good yank it will go into second and ride fine in that gear, it’s shifting into second that is an issue. This happens whether I use the clutch or not and if the engine isn’t running. I’m prepared to pull the motor and take apart the transmission but I don’t know what to look for messed up. Please help.
Before you take it apart, look at all the connections in the external shift linkage. If yours has a couple spherical bearings, like my Big Bear does, they wear and get slop in them. Mine would not shift out of 1st when I got it. I changed all the external stuff and now it works fine.
