HI All, I'm rebuilding a 2001 Kodiak 400 4x4 for a friend. It was not shifting well and the shift shaft needed adjustment. I was able to loosen the lock nut on the rose joints easy enough but turning the shaft was impossible. Long story short, I snapped off the top rose joint by the shift lever. I've not had any luck figuring out how to remove the broken rose joint. Everything leading to the joint is permanently stuck together. Has anyone had the remove one of these before and how do you dismantle the shift box to get to it. I've not been able to find any information anywhere. any help would be appreciated.
Sorry about the repeat on the question.
