95 magnum 425 running lean....i have removed and cleaned the carb, sprayed carb cleaner around the carb and boot to the intake, the airbox is silled, its mainly at high rpm. I removed the plastic around the tank and drove it down the road when i got it opend up it starts cuttin out and i can spray carb cleaner in the airinlet of the airbox and it runs good. I also took the air box off to look in the backside of the carb while its running and when i give it about half to 3/4 throttle fuel comes out the hole on the bottom side where the needle goes in and some sprays back towards the airbox side of the carb. Any help would be great:dunno: Thank you
runnin lean....
It seems like the jets are clogged or the floats are sticking. Also, check to see if there is any holes in the carb. boot to the cylinder(letting air in).
Also check fuel pumps and fuel filters=make sure there is no kinks in the fuel line....good luck:thumbsup:
