I have not went out to look at the bike yet.
Yesterday after a ride i tried to put my bike in 2X4 to do some donuts on the ice and it would not go. I also noticed the light not on at all(4X4 light).
I am assuming there may be a fuse for this?
Any help would be appreciated.
When I push the button on handlebar it does nothing.
I cant even here the actuator moving so i know it is not getting the signal.
I have a 2002 Yamaha Kodiak Ultramatic.
thanks for reading this and any help would be appreciated !!
Discussion Starter · #2 ·
update
well i just went out to garage and took a peak.
there was a 3amp fuse blown so i put another in and as soon as i turned it on she popped also!
I then put a ten amp fuse in to see if it would work and voila!! It works fine but i know i cant run it with a ten amp fuse as i can fry something else . sooooooooooooooooooooo i am off to the canadian tire (and yes they sell more than just tires)to get somemore fuses.
blowin fuses...
Most of the time when a fuse blows there is a short in that circuit(Hot touching ground). Do a physical and visual inspection on that circuit so the fuses don't keep blowing:thumbsup:
