Hi my Suzuki quadrunner lt160 has spark , compression ,good gasflow ,clean carb and turns over but will not start I'm having trouble figuring out the problem any suggestions on what it might be?
Well, if you're sure you have spark, but it doesn't fire on starting fluid, I'd go back and check the compression. Did you check with a gauge or just by feel ? Also maybe check valve clearance. A tight valve or one hanging open can cause this.
Discussion Starter #5
Update I checked the spark again plus compression and fuel and turns out my spark plug cap/boot is loose and the ignition coil is weak so I ordered a new ignition coil it will be here the 22nd thanks for the help
