A 49cc four-stroke single powers the Z50, the smallest youth machine in the Suzuki family. The machine is easy for youth beginners to operate with its electric start and smooth CVT automatic transmission, and built-in safety features like a throttle limiter and a cut-off tether that parents control are standard. The Z50 has a steel frame and an A-arm front suspension with coil-over shocks, and a single shock controls the rear suspension. The machine has a diminutive size, but looks all Suzuki with aggressive styling, LT-R inspired graphics and the bright team color scheme.
Engine Displacement/Type: 49cc air-cooled
four-stroke single
Fuel Delivery: Mikunit UM13 carb
Front Suspension: Single A-arm with coil-over shocks
Front Travel: 51mm
Rear Suspension: Single-shock
Rear Travel: NA
Transmission: CVT
Drive System: 2WD
Fuel Capacity: 0.7 gal.
Ground Clearance: 4.7 in.
Listed Dry Weight (lbs.): 167
four-stroke single
Front Travel: 51mm
Rear Travel: NA
Transmission: CVT
Drive System: 2WD
