· Registered
we were pulling the motor on a 2001 400ex, and the swing arm bolt that goes through the motor was stuck in and would not come out. took nut off one side and tried to beat bolt through and would not budge AT ALL!!! any tricks to getting one out without damaging the bolt???
· Registered
mine was the same way so i took i punch and put it in the hole in the big bolt and beat the piss out of it lol... i used alot of lube wd40 and let it sit..if u use bowes penitrating fluid it will prolly work better best of luck
