hi, i have just bought a new ktmsx450 09. i am trying to transfer from thumb throttle to twist throttle but the sensor in the throttle still needs to be connected so the bike doesnt cut out. does anyone know how i can get rid of the sensor or make it work using twist throttle? thanks
Are you saying that the replacement twist cable is interfering with the throttle sensor and how it goes into the carburator? If this is just a generic motorcycle twist throttle/cable assembly, then your problem may be in that the cable and cable housing may be too large. You may need a ATV specified twist grip assembly kit for it to work. Has your dealer/tech mechanic given you any help with this?
Delbert
