The Desert Cat 50 is powered by a 49.3cc oil-injected two-stroke, which gives it a peppy sound and feel as well as eliminates the need for premixed fuel. Unison says the engine produces 5.4 hp at 6,500 rpm. Drum brakes and a mechanical rear disc brake stop the DC 50. Riders will appreciate the floorboards and electric start. Reverse gear is available as an option. This quad can accommodate a 176-pound max load. The Desert Cat 50 Mini ($1,049) will arrive in dealerships soon.
VITALS
Engine type: 49.3cc air-cooled, four-stroke
Carburetor: Mikuni
Ignition: CDI
Starter: Electric w/kick backup
Transmission: Automatic
Driveline: Chain
Front shocks (travel, in.): Double wishbone w/shocks (NA)
Rear shock (travel, in.): Swingarm w/shock (NA)
Brakes f/r: Drum/mechanical disc
Tires f/r: 16 x 8-7/16 x 8-7
Length/width/height (in.): 57/34/36
Seat height: 28 in.
Ground clearance: 3.15 in.
Wheelbase: 34 in.
Dry weight: 226 lbs.
Fuel capacity: 1.3 gal.
Colors: Red, blue, black, white ($1,599)
VITALS
Carburetor: Mikuni
Ignition: CDI
Driveline: Chain
Seat height: 28 in.
Wheelbase: 34 in.
