Hi all,
I've got a 2002 vinson 500.
It will only start and run with the fuel enrichener on. If I shutnit off engine dies. It also wont rev up while its running with the enrichener on.
I can get it to stay running amd rev it up if I put my hand over the carb to partially cover it up. Otherwise it dies right away.
I have cleaned the carb three times, installed a rebuild kit.
There is lots of fuel coming out of the fuel valve, I ever removed it and cleaned the screens out.
Checked for air leaks, everything checks out. I'm at a point where I'm thinking I have to replace the carb but I dont really want to at $650 from suzuki.
Thanks for any help.
Tom
Got to have the complete airbox and filter in place b4 it will run right. No machine will run right without these. If it still doesnt run after installing these then your rebuild did not go correctly or check the intake manifold is leaking air. You are running lean, find the issue or you will burn a hole in the piston.
Proper rebuild kit has all new gaskets and diaphrams and full instructions for adjusting the carb.
