Hi,
I've got a 2001 Big Bear 4wd that has the factory installed Warn winch. It has the round winch controller mounted on the front
cargo rack. PO did something to the wiring and the winch is getting no power. I hear the relay click in the back when I turn the key on.
Now I highly suspect he has the power lead from the relay connected to the ground on the battery. I just want to make sure I have it
right before I let all the electric smoke out.
What I'd like is a picture of the hookup form the battery to the relay. It's not shown in the service manual.
First you will need a little more information. I replace a warn winch on a 1998 big bear.
The relay wiring is shown in this link( https://external-content.duckduckgo.com/iu/?u=https://wholefoodsonabudget.com/wp-content/uploads/2018/08/warn-winch-m8000-wiring-diagram-warn-m8000-wiring-diagram-winch-schematic-new-webtor-me-fancy-throughout-9r.jpg&f=1&nofb=1 ) This is the basic wiring diagram.
Here is the actual wire hook up to devices. ( https://external-content.duckduckgo.com/iu/?u=https://tops-stars.com/wp-content/uploads/2017/10/non-remote-using- function-very-easiest-motor-atv-winch-wiring-within-warn-atv-winch-solenoid-wiring-diagram.png&f=1&nofb=1 )
Hope this helps.
