so, ive got the quad running but...
i for the life of me can't figure out where the air/fuel screw is.....
the manual shows it as being here... number 1 on the picture....
but where is that on the carb??
would really appreciate some help/advice...
Font Circle Auto part Machine Drawing
If you look at the bottom of the carb, you should see a round boss. Now, its very possible they have
it blocked off with an aluminum or brass plug so you can't affect emissions settings. You need to
CAREFULLY drill a small hole through it and use a sheet metal or woodscrew screwed in there so
you can pop it out with pliers. Then, if you look in the hole you should see the slotted head of the mixture screw.
