I have a 97 warrior. Well the other day I was riding it in 5 or 6th gear can't remember. And it literally just locked the tires up and stalled. Well now it won't shift gears and iy sounds like its shifting gear., I can hold the clutch in and it will roll itself. Also it acts like it shifts down but soon as I shift up it says its on neutral. But if I go start it then it's clearly not and still in some gear. Took the clutch off and everything looks fine. Never messed with fourwheelers before so any help would be awesome.
If it rolls with the clutch in, it means the engine is seized.. If the trans was seized, the disconnecting the engine by using the clutch would make no difference. The gear change problems are probably just because the motor's not turning and the bike's not moving.
Try holding the clutch in and starting it, with the starter or manual start, or, turn the crank by it's flywheel bolt, there should be a bung to get at that I think.. I suspect it's not going to turn..
